question
Yanhao Z. avatar image
Yanhao Z. asked ·
dynatrace6.3 iis7
I use dynatrace6.3 to monitor a IIS7 instance. In in PurPaths view,I can see the Bussiess Information.But the purepath tree doesn't display detail infomation. eg:SQL、method invoking.
How can I see it ? Thank you !
6.3purepath
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Yanhao Z.
First of all, you must migrate to the latest version to get the proper support in case you required in the future. Secondly, make sure Web Server and ASP.NET are set as "active and start PurePaths".
You can also set the ADO.NET sensor capture settings as "active and start PurePaths" for the testing purpose.
Babar
Share
