question
Christian W. avatar image
Christian W. asked ·
DynaTrace AppMon API to select a PurePath and analyze the consisting SQL in it
does anyone know a possibility with a API of DynaTrace AppMon to select a PurePath and to analyse the consisting SQLs in this entry. Already checked the REST API but it seems not the right functionality.
Thanks in advance.
Christian
appmon 7rest apiadministration7.2rest
Serge P. avatar image
Serge P. answered ·
In AppMon you can use the XML reporting interface but you have to create first a rich client dashboard with at least the purepath dashlet in it.
Then if you specify purePathDetails with agent id and tag id you will get the equivalent of purepath tree, so with a little bit of XML parsing you can extract the SQL elements.
Serge
Share
Sebastian K. avatar image
Sebastian K. answered ·
There is no api that has any access to purepath.
Share
