• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Stephan D. · Jul 12, 2019 at 09:07 AM · appmon dashboard extensions plugins 7.1
JMX Enhanced Monitor Plugin | Metrics received (logs) but no measures avaiable for charting
Hello together,
as mentioned in the title I try to use the JMX Enhanced Monitor Plugin (https://community.dynatrace.com/community/display/DL/JMX+Enhanced+Monitor+Plugin) for AppMon 7.1 to receive metrics via JMX from an ActiveMQ.
I can connect to the ActiveMQ via JMX and I'm able to run the task, to create the available metrics group and I'm able to run the monitor.
The monitor returns a success state and because I set the log for the plugin on "finer" I can see that metrics are polled.
2019-07-12 08:40:51 UTC FINER [JMXMonitor@New JMX Enhanced Monitor Plugin_0] Entering getMGName method
2019-07-12 08:40:51 UTC FINER [JMXMonitor@New JMX Enhanced Monitor Plugin_0] Entering populateMeasure method: metric group name is '192.168.192.94.1099.org.apache.activemq.type.Broker.brokerName.localhost', metric name is '192.168.192.94.1099.org.apache.activemq.type.Broker.brokerName.localhost.MemoryLimit', value = 6.68309914E8
2019-07-12 08:40:51 UTC FINER [JMXMonitor@New JMX Enhanced Monitor Plugin_0] Entering buildMeasure method
The problem is, I can't see any metrics in the chart. I always get "No measurements avaialbe for the selected timeframe".
I added some screenshots as well. Please let me know if you have any ideas or if you can suggest an alternative plugin.
Kind regards,
Stephan
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Sebastian K. · Jan 15, 2020 at 07:43 PM
Did you succeed with this plugin? There are sources available so I think it's worth to make some reverse engeneering. This plugin was written 4 years ago so it's possible that there is issue with current appmon version.
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
29 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
How do we add timers to Selenium - Web Driver?
UFO_Alerter plugin created for AppMon 6.5+
How to track cache efficiency for different file formats?
Extended Email Plugin restart
Is it possible to use the PostgreSQL plug-in to monitor Greenplum databases in AppMon 7.1.x?
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
