question
Asrui N. avatar image
Asrui N. asked ·
PHP on Apache Httpd load dynatrace bootstrap agent failed
Hi everyone,
When I installed Dynatrace Appmon agent on PHP on apache Http 2.4.6 but PHP can not load php agent, I check with command #php -m and the result is below:
I can not find any information of this problem. Can you help me, please?
Thanks so much.
Best Regards,
A. Noiua
agent7.2apachephphybris
Asrui N. answered ·
Hi Sebastian,
Thank you for your support. I have fixed this problem. The collector can not connect to Appmon server port 8041, when I open this port, It worked. Thank you so much.
Share
Sebastian K. avatar image
Sebastian K. answered ·
The first image is missing now, but it is possible that you've configured wrong path in php.ini I think. Did you follow this instructions?
https://www.dynatrace.com/support/doc/appmon/shortlink/id_php_agent_configuration#install-configure-and-verify
Share
Asrui N. answered ·
Hi Sebastian, Here is log file from /opt/dynatrace-7.2/logs
dt_FOKR-APP02_bootstrap_19278.0.logdt_dtapacheagent24bo_FOKR-APP02_29881.0.log
Can you help me>
Thanks so much.
Share
Do you have any other logs available? I suggest collecting all logs and start support ticket.
Share
