question
Todd R. avatar image
Todd R. asked ·
Collector Cache Size Incident rule
Is anyone using an Incident Rule to monitor the total size of the Collector cache? If so, which rule are you using? I'm looking for something that will tell me when the cache reaches a certain threshold.
appmoncollector
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
In appmon there is Self-Monitoring system profile. I'm not totally sure but I remember that support was told me that it's discontinued and should be deleted. I can't find this information. Anyway, in this profile (if you have it) there are measures like this:
You can define such measure with threshold of your choice and make incident based on this.
Share
