question
matt k. avatar image
matt k. asked ·
remove Apache agent
Are there step by step instructions for completely uninstalling the Apache web-server agent including removing daemon from being auto-started with the proper order?
Dynatrace Managedagent
1 Answer
Joe H. avatar image
Joe H. answered ·
There is not specific uninstall directions, but you can simply follow the install directions as a guide.
Details are located at: https://www.dynatrace.com/support/doc/appmon/installation/set-up-agents/apache-agent-configuration/?appmon-agent%3C-%3Eclassic-agent=classic-agent
Note whether you're running the classic agent or the appMon agent. The difference is whether you have a separate WebServer Master agent process running on the Apache host. If you have a separate WebServer Master agent, you'll want to remove that as well.
Share
