question
Saqib M. avatar image
Saqib M. asked ·
How to monitor a JAVA cron job that is using Qartz scheduler framework
Hello all,
We have a cron process that is running using the Quartz Scheduler in JAVA. We need to monitor that using AppMon. KIndly help.
Saqib
appmonjavaclient7.2
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
In general you should define entry point sensor for those crons to start see purepaths.
https://www.dynatrace.com/support/doc/appmon/application-monitoring/sensors/#entry-points
When transactions will be monitorem, next steps is checking if you see everything you should see.
Share
