question
Nitin D. avatar image
Nitin D. asked ·
export the user Actions dashlet automatically?
Is there any feature in Dynatrace APPMON to export the user Actions dashlet automatically?
appmonappmon 7user actions
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
What you mean by export automatically? Do you want store sessions to a dts file?
3 comments Share
On User action dashlet, I have applied one filter which will showing some specific data .
That specific data, I want to export on every day at specific time.
I want to store the exported data into csv/xml format
0 Likes 0 · ·
You can crate dashboard with visit dashlet, apply filters there. Then you can save such dashboard and export it as data set manually. Such dashboards can be exported as report as well automatically:
https://www.dynatrace.com/support/doc/appmon/application-monitoring/reporting/scheduled-reporting/?_ga=2.28625791.2120227152.1564381003-69768096.1536581922
0 Likes 0 · ·
Thanks @sebastian k.
0 Likes 0 · ·
