question
Steven P. avatar image
Steven P. asked ·
[AppMon] How does purepath percentage affect measures based on sensors?
Suppose we have a sensor and measure on the return value of some method 'foo'.
If we then set 'Purepath percentage' to % on the agent group, do we get all invocations and values of 'foo', or only % of them?
Steven
appmonpurepathsensor
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
What is purpose to not catch all purepaths? They are not licensed anyway... But yes, purepaths data are calculated only for recorded part.
2 comments Share
Performance could be in play on high volume webservices, setting a lower value reduces the overhead caused by excessive purepaths.
The question mainly concerns the impact of that setting on business transactions. Do those numbers stay correct, or are there only x % taken into account when for example showing the number of requests for a specific BT.
0 Likes 0 · ·
It will never be through because you never now which % of transaction was handled. You alway will have some variations here. I rather suggest disabling some hard sensors from sensor pack to reduce overhead and leaving those that are needed + some custom sensor. We've got such high load enviornments and this is how we handled it.
0 Likes 0 · ·
