question
Nitin D. avatar image
Nitin D. asked ·
Unable to change Maxi Heap Memory of DT Client
Hi All,
I have tried to change the Client heap memory as mentioned in APPMON documentation. But is not getting changed it always keep the default memory (512 M).
May I doing it in correct way Or I have missing something?
After restarting the client again it is assigning the default value.
configuration7.07.1client
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
The question is settings direcory is writable. It looks that not. Do you have full control on this machine or it’s limited by organisation restrictions?
2 comments Share
Yes, I have the full control this directory.
0 Likes 0 · ·
You can try reinstall client to be sure that permissions are right. You can try as well portable client to check if that one will properly save settings. Those settings should be stored on your user directory in hidden .Dynatrace folder
0 Likes 0 · ·
