question
Nirmaljeet S. avatar image
Nirmaljeet S. asked ·
How can i get a cpu utilization of specific host/group of hosts using dynatrace REST API(timeseries)
I need to get avg/max cpu utilization of a specific host/group of hosts.Can we do it by using dynatrace rest api?
rest apirest
Nirmaljeet S. answered ·
@Ramesh N @sebastian k. I am asking by using dynatrace timeseries API.
1 comment Share
AppMon does not have timeseries api. Only Dynatrace have
0 Likes 0 · ·
Ramesh N. avatar image
Ramesh N. answered ·
Nirmaljeet,
To elaborate Sebastian suggestion. Follow below steps.
Create new dashboard add CPU utilization measure --> split specific host name --> save dashboard --> choose appropriate chart type & save it.
access below URL for rest api
https://<DT server IP>:8021/rest/management/reports/create/<dashboard name>?type=xls
You can change file type as per your need.
R
Share
Sebastian K. avatar image
Sebastian K. answered ·
Best option I think will be creating dashboard and using one of this endpoints:
https://www.dynatrace.com/support/doc/appmon/appmon-reference/rest-interfaces/server-rest-interfaces/dashboards-and-reporting-rest/
Share
