question
Yuting W. avatar image
Yuting W. asked ·
"Invalid password specified" for "Import and deploy certificate"
I am trying to import my certificate and my keypair ( a PKCS #12 ) file using the wizard in "Certification Management" Tab under Server settings. However i am getting "Invalid password specified" error. I am using the same password for the keypair. Can anyone help here? Thank you in advance.
appmonsecurity
Bhupendra R. avatar image
Bhupendra R. answered ·
i found that if you used non apha-numeric chars in the password , AppMon does not recognise the password . Just use a plain simple password . I used a $ in my password and had the same issue.
Share
Richard G. avatar image
Richard G. answered ·
The custom certificate requirements are found here: https://www.dynatrace.com/support/doc/appmon/installation/set-up-communication-connections/certificate-management/custom-certificate-requirements/
FWIW, we used OPENSSL to convert our P7B(PKCS7) format certificate to PEM format, then bundled into a ZIP file along with the servers' private key and root cert (also in PEM format).
openssl pkcs7 -print_certs -in <yourp7bformatcert>.p7b -out <yourconvertedpemformatcert>.pem
I haven't tried the PKCS12 format import, but possibly you are not including the private key or root cert, or they are in PEM format?
Share
Sebastian K. avatar image
Sebastian K. answered ·
Did you tried aCessna this certificate using different tool to check if indeed password is correct? From my experience, here everything should work as excepted.
Share
