question
Babar Q. avatar image
Babar Q. asked ·
Easy Way to Retrieve IP Addresses
Dear All,
Is there any way to retrieve the IP addresses of the monitored hosts instead of hostnames (which are showing in the infrastructure)?
Babar
appmon7.2
Dave M. avatar image
Dave M. answered ·
Not exactly easy, but you could access the "infrastructure.config.xml" file on the server and run the resulting host names through nslookup or ping to get the IP addresses.
Share
Sebastian K. avatar image
Sebastian K. answered ·
I don't know option in appmon for this as well. Even REST interface is not usable for this case :/
Share
