question
Matthias D. avatar image
Matthias D. asked ·
Dockerimage for Appmon Client
Has anyone experiences with a dockerimage to run an appmon client? Is there an dockerimage around to download?
appmon7.0
Sebastian K. avatar image
Sebastian K. answered ·
you can always try making such image by yourself but in my opinion it will not work. Appmon client consumes huge amount of resources when you have large scope analysing. In such case container will crash. You should rather consider installing appmon locally on remote computer that you can reach, or use portable version on computer that is available for you.
Share
Matthias D. answered ·
Hi Sebastian
I think of using a client running remotely in a kubernetes pod instead of installing it locally or even I will no longer have a local machine, but only a session on a workplace server.
I wonder, wheter it is a good idea, to use a container with an appmon client instead of starting it locally.
Regards
Matthias
Share
I don't think that there is such think. Appmon client is something that works on client desktop, not in monitored enviornment directly. What use case is behind this question?
Share
