question
Babar Q. avatar image
Babar Q. asked ·
Inter Tier Time/Transaction Understanding
Dear All,
I wanted to understand the Inter Tier Time of the following screenshot.
One transaction has taken 45.68s and the App tier contribution is 50.61%. On the other hand, I can see that the inter tier time for 10x calls to another tier (middleware) is 40.45s and the total contribution is 44.82%.
Is this due to the network between both tiers or something else?
Inter Tier Time/Transaction: Average latency time for transactions in milliseconds and total transaction execution time percentage.
Babar
appmon7.2transactionflow
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
InterTier time is difference between last call on first component and first recorded call for the same transaction recorded on second component. So In general it can be all, network, firewalls etc. I've had problems with InterTier time for enviornments that was working on single machine and were communication via localhost, there were problems with disk performance, in general app was slowing down during such communication and inter tier time was high as well.
5 comments Share
Hello @sebastian k.
It means we can consider that the inter time was spent due to a network or firewall (if exist) in between both tiers. The communication is between IBM WebSphere Application and IBM Integration Bus (WebSphere Message Broker).
What else can be considered in this situation?
Regards
Babar
0 Likes 0 · ·
Like I've said, appmon compares time of leaving 1st component and reaching 2nd component. So everything that can slowdown transactions. I've mentioned example for single host application where disk was root cause :) for architecture that is on multiple hosts I don't have extra idea right now.
0 Likes 0 · ·
Hello @sebastian k.
I always try to get the maximum from your practical experience, so, keep scratching your head, therefore, bare with me :)
Babar
0 Likes 0 · ·
Hello Babar,
In general - bigger resource contention is, higher intertier time you have.
I.e. it's a question of balance between # of workers / java (.net) threads / vCPUs and bare metal CPUs at the end. I mean in most of the cases it's the application (and its infra) problem.
Your case is about WSMB. An agent there, just "instruments" on the EXIT_PATHs. It means you have limited visibility of process definition and its end-to-end performance.
Scratch an extra square centimetre, to see what is the incoming request handler there ;-)
PS
In case of internal Data Centers and traffic encapsulated there, mostly never I see this problem because of NW active infrastructure.
Slawek
0 Likes 0 · ·
Hello @Slawek M.
IBM Integration Bus is already monitored by AppMon. The only thing is that we have multiple system profiles so PurePath is not correlated.
Babar
0 Likes 0 · ·
