question
jose r. avatar image
jose r. asked ·
error starting dtagent
Hello all,
when trying to start the weblogic jvm with the appmon agent I get this error.
2019-10-08 18:16:48 [00000002] info [native] Average transformation time for 1333 classes/modules was 0ms - maximum set to 60ms
[jfr][ERROR][0,989] Redefine class failed with 71
Error when initializing JFR. JFR will be deactivated.
java.lang.Exception: Could not instrument Throwable!
at oracle.jrockit.jfr.VMJFR.instrument(VMJFR.java:410)
at oracle.jrockit.jfr.JFR.init(JFR.java:109)
Error occurred during initialization of VM
Failed to start tracing backend.
How can I eliminate this error and start the weblogic?
thanks in advanced.
jose A
agentwebserver
1 Answer
Joe H. avatar image
Joe H. answered ·
Did you try turning off JFR and trying again? Basically JFR and AppMon are both trying to instrument your JVM and there appears to be a conflict.
What version of AppMon are you using?
As a last resort, you could tell Dynatrace to ignore the class(es) that's having trouble.
Let's first start with the above steps and go from there.
1 comment Share
turning off JFR works !!
thank you
0 Likes 0 · ·
