question
Mohammad E. avatar image
Mohammad E. asked ·
Where can we find list of incidents under installation directory in Dynatrace?
I need to check if multiple incident rules are copied into each system profile of a Dynatrace server.
If I can get a list of incidents for each system profile of a server, it will make my work easier than to go and cross check across all the system profiles.
In other words, how to search for multiple incidents in any system profile instead of searching one by one?
Please assist if anyone could.
system profile
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
You may export all system profiles, than you will have all of them included in XML. I don’t have any other idea :)
Share
