question
Mayana K. avatar image
Mayana K. asked ·
How can i enable the process/vm reboot problems in Dynatrace
Mayana Khan
Dynatrace Managedservicesdockerkubernetes
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Reboot isn't problem itself. But when you will go to process group, that you want to track when it is unavailable (shutdown, restart, crash), you should go to:
Process group of your choice => edit => Availability Monitoring.
You can change default behaviour, when problem is raised if service calls are affected.
Share
