question
Dominikus G. avatar image
Dominikus G. asked ·
AppMon 7.2 - Elasticsearch 7.3 compatible?
Hi guys,
does anyone have experience with appmon 7.2 and elasticsearch 7.3?
Thanks.
Dominik
appmon 77.2
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
Should work, but default (example) index may not work and have to be modified :) This is related to UEM export. If you want export BT’s than you should create proper index by yourself.
Share
