question
Shruthi B. avatar image
Shruthi B. asked ·
.Net core agent setup in AppMon
Our service is a .Net Core process running inside a Docker container on a Linux VM.
We are trying to configure Dynatrace AppMon for it. Do we have any documentation for it? Looking for something along the lines of how to pass the agent file path.
Example: Java agents are setup using JAVA_OPTS
We are using Dynatrace Appmon 7.2
How can you setup host monitoring of the VM and the container level monitoring? Do they need to be setup as different agents? One for host-level and the other for container level.
Shruthi
configurationagent7.2docker
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
According to documentation there is no .NET Core support for Linux based hosts in appmon:
https://www.dynatrace.com/support/doc/appmon/shortlink/id_system_requirements#supported-net-platforms
This feature works in Dynatrace SaaS and Managed.
Share
