question
Person P. avatar image
Person P. asked ·
Error occurred during initialization of VM ... Could not find agent library in absolute path
I am trying to monitor a spring boot application with dynatrace and I am unable to set -agentpath in JAVA_OPTS in my docker-compose file. But when run docker-compose up it fails throwing bellow error message:
apache_1 | 2019/10/22 15:31:09.520868 [INFO] consul-template v0.18.0 (5211c66)
consul_1 | Version: 'v1.2.0'
order_1 | Could not find agent library E:\softwares\dtagent\agent\lib64\oneagentjava.dll in absolute path, with error: E:\softwares\dtagent\agent\lib64\oneagentjava.dll: cannot open shared object file: No such file or directory
This is how I'm setting the -agentpath in my docker-compose file:
environment:
- JAVA_OPTS=-agentpath:E:\softwares\dtagent\agent\lib64\oneagentjava.dll=name=Java_mySystemProfile,collector=localhost
Your help on this will be appreciated.
agentjavaerrors
1 Answer
Joe H. avatar image
Joe H. answered ·
A few ideas:
1) Does the process being monitored have R+W access to the agent directory?
2) I assume there really is a file E:\softwares\dtagent\agent\lib64\oneagentjava.dll?
3) Try changing the path to:
E:\softwares\dtagent\agent\lib64\dtagent.dll
4) I assume your JVM is 64bit. If unsure, try changing your path to use \lib\ instead of \lib64\.
Share
