question
Ansuman D. avatar image
Ansuman D. asked ·
Impact of shutting down Dynatrace AppMon servers
Hi Experts
Any adverse impact on application if the AppMon server is switched off!
Meaning would the application ( Java, .Net, WebServer ) or any kind would continue to function with no errors if the host on which AppMon is running is down.
Would there be any impact on client side log directory filling up etc?
appmonjava
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
There should be no issue, in general agents will not be able to send data. If switch off is temporary, agent and collectors has some cache, so they will not have any impact. If you want permanently shut down server, they will work as usual but data will be lost.
But I suggest checking application start as well, we had issues with WAS as well for appmon and Dynatrace, when agent wasn't able to connect to anything, process sometimes wasn't able to start
1 comment Share
I agree with Sebastian. If you want to shut down the AppMon server permanently the best practice would be to remove the agents or least stop them so that they are not trying to connect to a non-existent server.
David Nicholls
0 Likes 0 · ·
