question
Service A. avatar image
Service A. asked ·
Automate appmon agents uninstallation on windows
Is there a way to automate uninstallation of appmon agents on windows.
Also, if there is a link to proper agent uninstallation in preparation for OneAgent installation, i couldn't found any.
Thank you.
appmonagent
1 Answer
Joe H. avatar image
Joe H. answered ·
Using a tool such as PowerShell, one can easily programatically uninstall any Windows installed app. I'm sure this will provide you the functionality you need to automate uninstalling AppMon Agent.
To prepare for the installation of OneAgent, simply uninstall AppMon Agent, then install OneAgent. There is no 'upgrade' procedure, these are separate agents.
1 comment Share
Thank you Joseph, can you please tell us what are exactly the steps to follow in order to remove dynatrace agent correctly and completely?
0 Likes 0 · ·
