question
Babar Q. avatar image
Babar Q. asked ·
Table Header Size
Dear All,
Any way to get the information about the table header size?
Babar
administration7.2
1 Answer
Akshay M. avatar image
Akshay M. answered ·
Can you elaborate this more, as to what exactly and which table you talking about
1 comment Share
Hello @Akshay M.
When application call Database then we can have the following information OOB:
  • Transaction Response Time Contribution
  • Percentage of Transactions Calling
  • Pool Usage
Sometimes you will find a failed query dut to a timed out issue. There could be many reasons, but one of them can be the size of the table header size, which can reduce the number of rows to load in the memory to process.
Babar
0 Likes 0 · ·
