question
Mevlüt S. avatar image
Mevlüt S. asked ·
How can i filter or split user actions by request header ?
Hi all ,
I created 3 different request header value which are host, connection and referer as you can see below.
And appmon started capturing these values in the user action purepath detail.
Everything is good until here but there are so different user actions as you can see below. The question is that how can i filter or split these user actions by request header ? For example, i want to show just the user actions which its request header value are host=localhost:8080 and connection=keep-alive or etc. How can i do that ?
I know there are many option to filter or split user actions but i couldn't see Request Header
Thank you,
Best Regards.
Mevlüt.
appmonuser actions
Mevlüt S. answered ·
Hi all ,
I solved this issue by creating BT and "Measure". I will explain step by step below.
  • First of all, I defined Request Headers what i want to capture. To do that, edit system profile go to Web Server Sensor Configuration and define Request Headers in the Web Server.
  • Then i created a new Measure (Web Request - Header Value). See below.
  • Finally, i created a new BT and i added the measures i created before.
  • Then, i filtered user actions with BT i created.
Best Regards.
Mevlüt.
Share
Babar Q. avatar image
Babar Q. answered ·
1 comment Share
Thank you for your answer @Babar Q. I did it. I will share the exact solution.
0 Likes 0 · ·
