question
John F. avatar image
John F. asked ·
Can I upgrade/migrate directly from dynaTrace 6.5 to 7.2?
Can I upgrade/migrate directly from dynaTrace 6.5 to 7.2 or do I first need to upgrade/migrate to 7.0?
John
migration
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello John F.
You can directly upgrade to the 7.2 from 6.5 version.
Have a look at the following link for more insight.
https://www.dynatrace.com/support/doc/appmon/installation/upgrade-and-migration-guide/prepare-to-upgrade/
Babar
Share
