question
Nicola P. avatar image
Nicola P. asked ·
Monitoring DB2 z/OS
Hi .. we have Dynatrace installed as agent on our IBM Webshphere Application. There is any possibility to do the same on our IBM DB2 z/OS?
I know that we can see application access on database with agent installed on application side, but we want more database centric control.
monitoringdatabase
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
In general DB2 cannot be monitored transactionaly using Agent. You will have no extra metrics as well. I don’t have experience with Z/OS but you will have host and process stats only.
Share
