• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Mevlüt S. · Nov 12 at 01:04 PM · appmon uem business transaction user actions
Is there a way to calculate the passing time between two user actions ?
Hi all ,
I am wondering that if i calculate the passing time between two user actions or not. For example, there are two actions below and the result should be 1min 20s.
Action 1 : click on "Start Action" : 10:00:00
Action 2: click on "End Action" : 10:01:20
I also want to give an example scenario of this situation. Think that, you want to buy something from an e-shopping web site and you go www.something.com and then countinue as below.
1- Firstly, you click "Product" you want to buy: 10:00:00
2- You click "Add to basket" : 10:00:20
3- Then you set your payment choice and type your credit card information then click "Next" : 10:01:30
4- Lastly you click "Okey" then your order is accepted and your visit finish : 10:02:00
According to above scenario, your buying time is 2 minute. I could capture these begin and end user actions with request header paramater but i could not calculate the passing time between two actions.
Regards.
Comment
People who like this
0 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Sebastian K. · Nov 14 at 10:42 AM
You cannot make it directly in Dynatrace (at least so far, I’ve read somewhere that there are plans for some extra tools related to those data but I can’t find topic). You can export user sessions to ElasticSearch via built in integration and than you will be able to make such calculations.
Comment
0 Show 2 · Share
â–¼
avatar image Mevlüt S. · Nov 15 at 11:13 AM 0
Share
Thank you for your response Sebastian. I want to ask you one more question regarding this topic. Can i export all user action with request parameters that i capture to ElasticSearch or other external tool ? In this way, i will split user actions by request header, and i understand which user action is the first and which is the last action then i will calculate the passing time between these two actions.
Note: Every user action includes 3 uniqe request header values, we understand which is the first and which is the last action according to these values. So if we won't export request parameters, this scenario can't work for us.
avatar image Sebastian K. Mevlüt S. · Nov 15 at 01:28 PM 0
Share
User actions are not correlated with request headers. I've missed last time that you've asked question in appmon not dynatrace forum. In such case you can export user visits as well to ElasticSearch but you will not have header information. Purepaths (which has this information) cannot be passed.
https://www.dynatrace.com/support/doc/appmon/shortlink/id_purelytics_stream#the-json-document-format -> here you have sample JSON's that can give you some insights about what you will see in Elasticsearch.
EDIT:
https://assets.dynatrace.com/global/doc/appmon/integrations-and-extensions/realtime-streaming/purelytics-stream/browser-useraction.txt?_ga=2.140012208.262802410.1573739538-925302736.1568972215
When you look here, in user action you should be able to see correlated business transaction, so you can try making user action business transaction that will split by request header, but I'm not sure if this work.
Join the conversation!
First steps in the forum
Community User Guide
LIVE WEBINAR
"Power Demo: Software Intelligence for Cloud Infrastructure"
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Register here
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
35 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Moving Session Storage data to Performance warehouse 2 Answers
Track multiple same button clicks per user 2 Answers
Filtering Business Transaction Result Charts by Visit 1 Answer
we want to export some reports from dynatrace and import it to BCO BMC 4 Answers
User Actions not getting tied with server side purepaths/web-requests 3 Answers
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api errors dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java browser agent community user guide hybris javascript appmon sensors good to know search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow diagnostics user session monitoring unique users continuous delivery configuration alerting NGINX splitting business transaction client 6.3 installation chart database scheduler apache mobileapp RUM php dashlet azure purepath plugins agent 7.1 appmonsaas messagebroker nodejs 6.2 incidents android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
