question
Carles F. avatar image
Carles F. asked ·
How can I create a dahsboard in APPMon to get the availavility of all the servers (PSD2)
Hi. We need to create a report for PSD2 with the availavility (% time online) of every server. How can we get this value in a dashlet in AppMon? Thanks in advance
dashboardmeasuresdashlet
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
You should create such measure:
Than you can create proper charts on single dashboard for each agent itself. Unfortunatelly it cannot by done for hosts. At leas I don’t know such measure in Appmon.
2 comments Share
Thank you very much! Do you know if this measure is available in version 7.0 of AppMon?
0 Likes 0 · ·
Should be, but you have to create new measure, not check list of built in ones.
0 Likes 0 · ·
