question
Service A. avatar image
Service A. asked ·
Extract business transaction APPMON
Hello everyone,
I'm trying to extract my business transactions for each System profile on APPMON and i couldn't really find a proper way.
I just want the list not the performance.
i can't do that with a dashboard and then a report because the dashboard gives you the metric values and i just want the list of the BT.
I also tried the Copy Paste but it's not really organized.
I just want a way to have the list of my BT on an excel file for example.
Thank you
appmonconfigurationdashboardbusiness transactionreports
1 Answer
Babar Q. avatar image
Babar Q. answered ·
Hello @Service A.
Just add a dashboard/dashlest for each system profile and the business transactions dashlet, then click on the ... on the right side of the dashboard or Ctrl+P to generate a report. Select your desired format and click on generate. It will take some time to show the generated file.
Once the file is generated then you can make another file where you can place (copy/paste) all the business transactions.
Babar
1 comment Share
But it still gets you the liste in a defined timeframe with the values
so when you export it you find all the information + the BT are in doubles or more so you have to re organize it again which is more work to do.
i need to find a way to just extract the configured list on a certain SP.
0 Likes 0 · ·
