question
Devi S. avatar image
Devi S. asked ·
How to find the names of the clients that are connected?
In one of the answers it was mentioned that the measure "Client Socket Connections" will display the client connections and when split by the host, it would display the connections per client and thus find the client names. I tried that measure but it is only showing the DT server host as the split value and not the client names.
How do we find the names of the clients that are connected to the frontend server? We are in 7.1
appmon 77.1clientmeasures
1 Answer
Jacob P. avatar image
Jacob P. answered ·
Hi Devi,
When you choose to split a metric by host, the metric is split by the agent's host. However, the AppMon clients are not instrumented by an agent. Instead this metric is only collected by the Dynatrace server host. This means the split by host option will not have an effect. I believe the best place to find this sort of information is in the audit log files which can be found system information dashlet. You can use the audit log to identify users that have logged along with their IP address and username.
Jake
Share
