question
Nitin D. avatar image
Nitin D. asked ·
How to restore System profile when Dynatrace servers are not working
Hi ALL,
Due to some issue the dyantrace Front-end server are not getting started, Due to that I am unable to connect the Dynatrce Client.
Is there any way to restore the system profile when the Dynatrace server is down?
appmon 7system profile
1 Answer
Jacob P. avatar image
Jacob P. answered ·
Hi Nitin,
The front-end server is responsible for managing client connections. When the front-end server is offline you will not be able to connect to the Dynatrace server. If the back-end server is still online, then I expect that your system profile configurations continue to work as expected while the server collects data. My recommendation is that you get the front-end server back online rather than restoring the system profile to a new server. If you choose to restore the system profile to a new server you will lose historical session data and historical performance warehouse data.
However, if you really need to restore the system profile to a new server while the server is offline you can copy the profiles xml document from <DT_HOME>/server/conf/profiles to the same directory of another offline server.
Jake
Share
