question
Monique V. avatar image
Monique V. asked ·
Dynatrace appmon find oldest transactions
Due to some changes in configuration (adding eum) our storage was not covering detailed data retention for 7 days.
We extended the storage, but I want to follow up how many days the purepaths are retained.
I found a number of simular items in the forum, but all of them are older and I do not find same possibilities with current version 7.2.12 (that had lots of interface changes)
Can someone tell me how I can find back what the oldest purepaths are that are kept in detail ?
thx
purepath7.2
Darren M. avatar image
Darren M. answered ·
Hopefully this "Hack" will still work with 7.2. Enable degug mode CTRL+SHIFT+F9 you will see [DEBUG] in the bottom right. Then open the 'Stored Sessions' dashboard and it will list all the Session files containing Purepaths with their start dates on the server.
1 comment Share
Great....This still works.
I now can follow up in a very fast way (iso by trial and error looking where I find the last PP)
Thx a lot
0 Likes 0 · ·
Sebastian K. avatar image
Sebastian K. answered ·
You should go to System Profiles => Right click on the one you want to check and there should be details button or something like that. I don't have appmon server with easy access to check. You should see model where there is date you need.
1 comment Share
For those that does not want to use hacks. Go to System profile list:
click Details:
Recording since is the date of oldest transactions.
0 Likes 0 · ·
