question
Lee R. avatar image
Lee R. asked ·
Exclude HTTP 500 - Internal Server Error
What is the best way to exclude some specific " HTTP 500 - Internal Server Error" with Runtime.NoViableAltException
iis
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
You can always go to System Profile => Agent Group => Sensor Configuration
You have to edit .NET Exception or Java Exeption sensor, and add exclude rule for this request. But they will rekord as HTTP 500 as well because this is code returned by WebServer. As I understand, you want to not count this error as failure rate, right? Actually Error Detection rules allows only adding extra ones, but not excludes. Try what I've suggest, and tell me about results.
2 comments Share
I am using APM SAAS. Where is this setting ?
0 Likes 0 · ·
If you have Appmon in SaaS, this is in place I've mentioned. From left menu in Dynatrace client pick System Profiles, and than according to my answer.
0 Likes 0 · ·
