question
Cecilia R. avatar image
Cecilia R. asked ·
VERY_UNHEALTHY: Decreased throughput
In AppMon is there a way to narrow down which agent/profile is causing the throughput decrease. I am also seeing the pure paths increase on the Server health dashboards when this happens but I can't tell which agent is the cause. Thanks in advance for your response.
here is what I am seeing in the logs
2019-12-05 13:16:52 UTC WARNING [AggressiveThroughputAdaptingHealthAction] VERY_UNHEALTHY: Decreased throughput by 20% from 100% to 80%
2019-12-05 13:17:43 UTC INFO [AsyncMeasureTimeOuter] The measure timeouter ran for 50519 milliseconds.
2019-12-05 13:17:53 UTC WARNING [AggressiveThroughputAdaptingHealthAction] VERY_UNHEALTHY: Decreas
appmonalertingagentserver
1 Answer
Sebastian K. avatar image
Sebastian K. answered ·
You should create chart that will use PurePath Response time measure splitted by Agents. Pick aggregation count (you will see number of purepaths per agent). Than you can correlate spikes from server health with particular agent.
Share
