question
jose r. avatar image
jose r. asked ·
Permission to create users
Hi all.
What permission should I assign to be able to create and edit users?
thanks in advanced.
jose A
administrationscheduler
1 Answer
Jonny S. avatar image
Jonny S. answered ·
Hello Jose,
To create and edit users you will need to have the "Manage User Configurations" permission, but you will also need the "Manage Server Configurations" permissions to be able to access the server settings where User management is.
You can read more about the specific permissions in AppMon here: https://www.dynatrace.com/support/doc/appmon/administration/user-permissions-and-authentication/permissions-mapping/
Cheers,
Jonathan
Share
