• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by jose r. · Feb 18, 2020 at 01:34 PM · appmon apache mainframe
starting IAS
Hi all.
when I start the IAS I receive this message:
/Ias103/as103/Apache/Apache/bin/apachectl startssl: execing httpd
Syntax error on line 245 of /Ias103/as103/Apache/Apache/conf/httpd.conf:
API module structure `dtagent_module' in file /Ias103/Dynatrace/dynatrace/agent/lib/libdtagent.so is garbled - perhaps this is not an Apache module DSO?
but don´t start.....
any idea, something i must review
thanks in advenced
Jose A
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by jose r. · Feb 20, 2020 at 04:06 PM
I have reviewed this part and it is correct,
any other idea ?
Thanks a lot!!
Jose A
Comment
0 Show 2 · Share
avatar image Dave M. · Feb 20, 2020 at 10:48 PM 0
Share
So your Apache is 32-bit? Is the LoadModule at the end of your httpd.conf or at least after all the other LoadModule statements? Have you tried redownloading to verify the file is not corrupt?
avatar image Dave M. · Feb 20, 2020 at 10:51 PM 0
Share
Does the master agent start ok? That would indicate you have the right OS binaries...
avatar image
Answer by Dave M. · Feb 18, 2020 at 03:30 PM
First thing I would check is that you reference "lib64" instead of "lib" if you have a 64-bit web server.
Comment
0 Show 1 · Share
avatar image jose r. · Feb 20, 2020 at 10:43 AM 0
Share
Thank you Dave.
i will check.
best regards
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
25 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
How to get the CICS API Execuction (and CPU) metrics?
Will ApacheNodeName work for IHS (IBM HTTP Server)
Why is DT showing our webservers as having a very long execute time?
Apache agent installation issues
Is it possible to perform basic AppMon (v6.5) host monitoring on an IBM i series (i 6.1.1) lpar?
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
