If the same agent name is used in WebServerAgent, the index number [1] will be appended to it.
However, there are agents that are not assigned the index number [1] in the customer environment.
Since no index number is assigned, two Apache processes should exist, but they will be merged into one. (On the transaction flow)
Please let us know if you have any knowledge of this event.
Answer by Jake P. ·
Hi Kazuya,
I would not recommend a setup where you have duplicate agent names especially if they are on the same host. In order to avoid this situation I would recommend adding the server flag that enables unique agent names with index.
https://www.dynatrace.com/support/doc/appmon/installation/set-up-agents/unique-agent-names/
Jake
