I am trying to perfom same using MQ Queue Channel Monitor Updated plug-in but i am getting exception.please let us know if is there any way to monitor Apache Active MQ?
Answer by Sebastian K. ·
ActiveMQ is populating metrics via JMX, so in general you can install agent and create custom measures based on JMX values. Than you can create dedicated dashboard for than.
Thanks Sebastian.
But i want to monitor Queue depth for diff channels which i am not getting in custom metrics.
can u share any snap if u have which showing queue depth metrics .
Prasad
