• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Andre F. · Aug 06, 2020 at 06:26 AM · appmon apache webserver
Apache agent installation issues
Hi Everyone,
I ran into an issue after installing the Apache agent. The Web Server Agent is already connected to the Dynatrace server, but I can't see the monitored metrics. I have loaded the dtagent script into the httpd.conf file then restarted the apache service, but the Apache agent is not connected to the Dynatrace server. I am attaching a screenshot of the Dynatrace client.
Has anyone had an issue like this? I am using Apache 2.4.6 64 bit.
Thank you.
Andre
Comment
People who like this
0 Show 1
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
avatar image Andre F. · Aug 06, 2020 at 06:36 AM 0
Share
Sorry I have to attach in the comments
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Dave M. · Aug 07, 2020 at 02:52 PM
Always double-check that you got the right "bitness" for the process. Usually, we want to load the agent located in the "lib64" path and not the "lib" path. That often causes this sort of issue...
Comment
Richard G.
1 Show 0 · Share
avatar image
Answer by Dave M. · Aug 06, 2020 at 02:24 PM
I suspect that your Apache is not instrumented correctly or is unable to communicate with the Web Server Agent as it should. Check the agent overview and verify the Web Server Agent has a "child" Apache agent under it. If not, check the Agent logs and Apache logs to see if the agent failed to load as expected.
Comment
Maciej N.
1 Show 1 · Share
avatar image Andre F. · Aug 07, 2020 at 08:54 AM 0
Share
Hi Dave,
Thanks for the help, unfortunately there's no Apache agent under the Web Server agent. I will open ticket to support for now and send the logs to them.
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
30 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Web server agent getting disconnected during collector switching. And same is getting connected after restarting collector
Configure Dynatrace Appmon 6.5 for my Apache web server on Linux Box.
The most stable Nginx version for Dynatrace agent
Web server busy threads showing zero count.
Enabling WCF sensors
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
