• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by hghjg h. · Oct 08, 2014 at 11:30 PM ·
Tibco BW monitoring
 I installed dynatrace 6.0 trial version and trying to monitor a  TIBCO BW system for which I created a system profile and added the application server - Java and then added the string for java agent in  BW tra file(located in TIBCO installation folder) and restarted the TIBCO and dynatrace services but still the agent is not getting loaded.(Note : Both dynatrace and Tibco are on the same windows machine)
java.extended.properties = -agentpath:"C:\Program Files\dynaTrace\dynaTrace 6.0.0\agent\lib64\dtagent.dll" =name=JAVA_Monitoring,server= localhost:9998
Can you please guide if there are any other steps to be done for the agent to get detected ?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Oct 09, 2014 at 12:08 AM
Hi
Thanks for posting this after we didnt get that resolved during our webex yesterday. I hope to get some Tibco Experts here on this forum.
In your scenario you launched your TIBCO Administrator as a windows service. Based on the feedback I received from a colleague after we finished our webex it is very likely that there is a different tra file you need to edit. Therefore - please have a look into your installation directories and check which other tra files are floating around.
Andi
Comment
0 Show 0 · Share
avatar image
Answer by Todd E. · May 19, 2015 at 06:38 PM
Not sure if this was resolved but this is what we do. When a project is deployed, it clones something called the bwengine.tra thus making a Projectname.tra. Edit the cloned bwengine.tra and when you restart, you will see your changes in the Projectname.tra. You should now be able to connect to DynaTrace.
Todd
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
