• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Gokhan K. · Aug 05, 2015 at 10:27 AM ·
dynatrace feedback - unusable product
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Gokhan K. · Aug 05, 2015 at 10:29 AM
It was not possible to configure dynatrace in our environment.
It requested 4 restarts and it still cannot be started.
I'm very disappointed with dyntrace.
I cannot imagine how long it will take to install this product to 900 servers?
Mission impossible.
WHy should I restart IIS, WAS, WWW 4 times?
And the product still does not work after 4 restarts?
Comment
0 Show 7 · Share
avatar image Reinhard W. · Aug 05, 2015 at 11:26 AM 0
Share
I'm sure there is just a simple error somewhere. Either a small config setting gone wrong or similar.
Can you post any log files from your WAS, Dynatrace Server/Collector?
Usually after everything is configured correctly only one restart is required and you are ready to go.
Btw. some of our customers have thousands of components monitored and update them automatically after an initial configuration.
avatar image Gokhan K. Reinhard W. · Aug 05, 2015 at 02:11 PM 0
Share
This is the warning I found in one of the log files:
2015-08-05 17:01:01.820646 [13972/000001b8] warning [native] Starting without instrumentation, agent did not match a system profile.
avatar image Reinhard W. Gokhan K. · Aug 05, 2015 at 02:39 PM 0
Share
This means there is a mismatch for the agent name (the parameter you added to the JVM argument) and what was configured on the dynatrace side.
Can you post your full Java argument path that you use to launch WAS or the configuration you made for IIS?
Also your System Profile would be interesting as that's were the mapping is defined.
Did you use the configuration wizard upon first launch of dynatrace or configure it manually?
avatar image Gokhan K. Reinhard W. · Aug 05, 2015 at 02:43 PM 0
Share
I don't understand your questions well. THis is the first time I'm using Dynatrace.
Your partner in my country came and created a "profile". I think this system is not in that profile.
I don't know how to add it there either.
avatar image Reinhard W. Gokhan K. · Aug 06, 2015 at 11:45 AM 0
Share
Gokhan,
I've learned that you also are in contact with our free trial support. They told me that there was some misconfiguration caused by a customized System Profile created by a partner. Were you able to resolve your issues with our free trial team?
Reinhard
avatar image Allan S. Gokhan K. · Aug 06, 2015 at 08:40 PM 0
Share
Hi. Sounds like you're using a product version prior to 6.2 as well. 6.2 would have automatically mapped the agent to the default system profile. I highly recommend making sure you are using 6.2 regardless of the issue.
avatar image Gokhan K. Allan S. · Aug 07, 2015 at 07:23 AM 0
Share
I received another reboot request from Dynatrace representative. What a bad product! I restarted everything 17 times but it still requires a reboot.
avatar image
Answer by Gokhan K. · Aug 05, 2015 at 02:26 PM
I think it should not be so difficult to setup this software.
I have only 3 systems for Dynatrace and  I took 1 month to setup.
Still it does not work.
I cannot understand this.
Unacceptable.
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Aug 07, 2015 at 10:36 AM
FYI - cross linking two parallel discussions here: Install is not possible
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
