Hi All,
I have the next weird behavior with the chart of the purepaths, when I select two or more agents in the options of the chart, as the next image shows.
I get the next chart, but if I select all option, the chart display the analysis for the all agents good.
this behavior is an issue of dynatrace? the version that I'm using is 4.1.0.2974.
Thanks in advance.
Joan Alonso
Answer by Roman S. ·
Maybe there was no data from those specific agents during that timeframe?
If you do see data series for those agent names when you select all I would suggest opening a support issue as someone should take a look at this in detail...
Best, Roman
Hi Roman,
Thanks for your answer, when I selected all the agents I saw data series in the graphic for that group but if I only select more than one agent nothing is displayed. I checked charts for other topics, for example CPU Load and Used Memory, and when select the same agents the chart display the data series for it. Well I will open a ticket for this behavior 'cause is strange.
Joan Alonso
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
