• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Derek A. · Dec 11, 2012 at 05:45 PM ·
Estimated CPU Overhead
I don't see that there is a dynaTrace self-monitoring measure called Estimated CPU Overhead anymore in 4.2. This measure was in previous versions and showed you the percent overhead caused by the dynaTrace agent. Has then been removed or just renamed? I didn't see any other measures similar in name. This helped us get a better idea of how much overhead the dynaTrace agent is causing.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by McKenna J. · Dec 11, 2012 at 05:55 PM
I have seen this question before, but instead of risking confusing you by me trying to explain it I think what you are looking for is here
Comment
0 Show 0 · Share
avatar image
Answer by Derek A. · Dec 11, 2012 at 06:03 PM
Getting a page not found.
Comment
0 Show 3 · Share
avatar image Andreas G. ♦ · Dec 11, 2012 at 06:11 PM 0
Share
Hi Derek
This was a post on the internal forum. I've just moved it to the public forum. you should now be able to access it
Andi
avatar image McKenna J. Andreas G. ♦ · Dec 11, 2012 at 06:15 PM 0
Share
Ah i didn't even realize...
avatar image McKenna J. · Dec 11, 2012 at 06:14 PM 0
Share
Hmm well in 4.2 the best way to measure CPU overhead in dynaTrace is the use the CPU Sampling under Diagnose Runtime. You will then be able to see how much time is spent in dynaTrace code that has been instrumented into the application. I hope this helps get you started.
avatar image
Answer by Derek A. · Dec 11, 2012 at 06:15 PM
Thanks I got to the page now and it answers my question.
Comment
0 Show 0 · Share
avatar image
Answer by Derek A. · Jan 09, 2013 at 07:57 PM
Is there a better way to do this other than creating a CPU sampling? I want to be able to better monitor the CPU overhead on 400+ applications and would prefer not to have to set up CPU samplings on all applications and have them run constantly.
Comment
0 Show 1 · Share
avatar image Andreas G. ♦ · Jan 11, 2013 at 11:30 AM 0
Share
Hi Derek
right now there is no better way to measure the "estimated overhead" per agent.
Andi
avatar image
Answer by Derek A. · Jan 15, 2013 at 05:20 PM
Are there any plans in later releases that this will become easier to get?
Comment
0 Show 1 · Share
avatar image Christian S. · Jan 15, 2013 at 05:36 PM 0
Share
hi Derek,
there's already some approaches that we've been thinking of to get such a (hopefully) meaningful overhead estimate.
so i'm very confident we will have something in future releases, but i cannot tell when that will be.
best,
Christian
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
