• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by George F. · Dec 22, 2012 at 04:24 PM ·
Appplication Overview not showing current time interval (5.0)
It seems that my Application overview time frame is 'stuck'  to a few days ago ( December 19 ) when I had baseline violations rather than the CURRENT time frame.
Image if my current ( Dec 22 )  Application overview shtowing DEC 19 timefram attached
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by George F. · Jan 10, 2013 at 06:36 AM
Support helped resolve this issue.
Problem turned out to be that the view was 'locked' to the specfic time fram while in DEBUG Mode.
Comment
0 Show 0 · Share
avatar image
Answer by George F. · Dec 24, 2012 at 04:47 AM
Yes - Client re-start does not help .
I have opened a support ticket for this and a couple other issues
Unfortunately our dynaTrace 5.0 migration ( from 4.1 ) experience has has not been a stable one so far.
Comment
0 Show 2 · Share
avatar image Andreas G. ♦ · Dec 24, 2012 at 10:55 AM 0
Share
Sorry to hear that you ran into issues when upgrading. I am sure you get helped by our tech support team
If there is anything else we (the community) can do for you let us know
Andi
avatar image George F. Andreas G. ♦ · Dec 24, 2012 at 11:12 AM 0
Share
Thank you. Will post  resiltions  when they become available.
avatar image
Answer by Andreas G. · Dec 22, 2012 at 04:34 PM
Hi. This is an odd behavior. If it says last hour it should be last hour.
Can you click on your application overview (first tab in the breadcrumb) and then Hit F5 (or refresh). Will it refresh to the current timeframe then?
also - next to the Blue Home Button in the toolbar there is a little drop down that allows you to select the System Profile. Make sure you have selected the current system profile and not a stored session.
Andi
Comment
0 Show 4 · Share
avatar image George F. · Dec 22, 2012 at 04:41 PM 0
Share
Thanks for quick reply .
Already took the actions you outlined but no change .
I'm stuck in the same time fram even when change profiles - even profiles from diffrent dynaTrace servers.
avatar image Andreas G. ♦ George F. · Dec 22, 2012 at 04:50 PM 0
Share
Here are some additional things you can check
1) Client and Server Log Files: access them through the System information dashlet. Look at them and check if there is any error output that would give you more indications
2) Verify that data is still captured till that timeframe: create a dashboard and chart those Business Transactions that you have specified on your Application Overview, e.g: displayLogin. The AppOverview shows data from those BTs that you have configured. If there is no data coming in on that BTs the behavior might be (although I am not certain) - that the appoverview might just show the last hour of available data
Andi
avatar image George F. Andreas G. ♦ · Dec 22, 2012 at 07:03 PM 0
Share
No Errors in Client Log
BTs showing uptodate information
I guess I need to open a support call
avatar image Andreas G. ♦ George F. · Dec 23, 2012 at 04:27 AM 0
Share
I assume you have tried restarting the client? If that doesnt help as well you should open a support ticket. Please keep us posted
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
