Does Dynatrace 5.0 supports agent insatllation & monitoring for WebSphere Message Broker on RH linux.
Can you please let me know the steps or where I can find in the documentation:
1) Steps I need to follow in the WMB server (linux) to install the agent
2) Steps to setup instrumentation in dT client, for monitoring WMB.
Answer by Kevin J. ·
Sangal-
I believe the only officially supported platforms for the WMB agent today are for AIX and Windows; however, it should work on RHEL the same way as for AIX and Windows. The main difference is that in the dtwsmbagent.sh file, the path of the bash reference at the top should be changed to '#!/bin/bash', rather than '#!/usr/bin/sh'.
Everything else in the online documentation should be the same. Here is a link to the documentation: dT 5.0 WMB agent docs
Kevin
