• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by James M. · May 21, 2013 at 11:06 PM ·
Getting a Low Server Memory-Failed to load PurePaths data
Quick Question: we are running a pretty active dynaTrace server with around 450 agents on it; 12Gb RAM for dynaTrace; 64Mb for the ReservedCodeCacheSize; 256Mb for permgen.
We are getting a dynaTrace error on the client PurePaths dashlet saying "Low Server Memory: Failed to load 'PurePaths' data", and we can't see any data as a result. First the methods disappeared and now we can't see any purepaths at all, even though there's lots of traffic trying to come into the server.
What should we do to address this?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Rob V. · May 22, 2013 at 04:42 AM
James,
This will happen if you have many people using the dT client, trying to do PurePath-based analysis (anything under the Diagnose Performace cockpit option) over long(-ish) periods of time. In addition to all the work the dT server is doing processing incoming data, those sorts of analyses will read data into memory and compete for heap space. That leads to the "Low Server Memory" warnings.
The best way to address this is to use PW-based charts, or perhaps incidents, to target/refine the PurePaths (and related data) that you are browsing. Diving straight into PP data and then drilling around in a 450 agent system is going to consume significant resources.
Rob
Comment
0 Show 0 · Share
avatar image
Answer by James M. · May 22, 2013 at 02:26 PM
I get the memory management challenge. We have on average 11-13 clients hitting our server, each working with different profiles/different systems. There are around 500 agents hitting the server, spread out across 55 profiles. So getting the user base to shift how they are using the product won't be quick or easy.
Two questions: how can I get alerted when this is occurring, so we know that the server is under stress. And will either increasing the heap memory allocated to the server or upgrading to 5.5 help with this?
Comment
0 Show 0 · Share
avatar image
Answer by Klaus E. · Jul 09, 2013 at 08:00 AM
There is an out of the box incident rule "Low dynaTrace Server Memory".
Upgrading to 5.5 is definitely a good idea as the performance improvements compared to 5.0 are ~25%.
Klaus
Comment
0 Show 0 · Share
avatar image
Answer by Sreerag M. · Dec 09, 2013 at 08:16 PM
We do face the issue pointed out by James, We have the same server configuration with 650 agents, 15 - 30 clients. We also face the analyze purepath load issue. Something which we have been trying is to store the session and move the session to another dynatrace server for deep purepath analysis. Currently we don't do it that often as moving session files is a manual process. Current system doesn't allow us to save the stored session directly in a different location than the live session.
We have opened and RFE to solve this  Option to specify different path for continuous session and store sessions.
This way we could restrict the purepath analysis on the primary server to only the live session data and direct all deep analysis to the secondary dynatrace server.
-Sreerag
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
