• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Sanjay S. · Nov 29, 2013 at 08:10 PM ·
Export Query string from multiple purepaths
Hello! Am new to dynaTrace and recently concluded some training, so apologies in advance if the question is silly.
We have identified a list of purepaths that are causing some issues. We wanted to export all the query string parameters for all purepaths. I could not see a way to add the query string parameters to the purepath columns view dashlet (so as to generate a report on this view). Is there any way I can export all the query string parameters say into a .csv file.
Thanks in advance.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Dec 01, 2013 at 05:31 PM
Hi. The best way to do is is to
a) Multi-Select the PurePaths you want to analyze
b) Drill Down to the Database Dashlet
c) in the Toolbar of that Dashlet you have the option to "View Bind Values"
d) Now you have a list of SQL STatements including Bind Values in the bottom list that you can e.g: Copy / Paste to Excel
OPTION B: Share PurePaths
Instead of Generating a report of SQL Statements you can also "Share" these PurePaths with your colleagues that need to look at them. You can for instance create a dashboard that shows exactly the Database Dashlet as explained in the above steps. Instead of exporting the data to an external tool you can also click the "Share ..." Toolbar Button. This will save the current Dashboard on the dynaTrace Server and copy the link to this dashboard to your clipboard. Now you can share this link with your colleagues. When they click it they will automatically get to this dashboard showing them the data they need
Comment
0 Show 0 · Share
avatar image
Answer by Ted F. · Dec 02, 2013 at 08:51 PM
Hi Sanjay,
If you mean the DB Queries, then follow Andreas's advice.  If you mean the HTTP Query String, then:
A) Multi-Select the PurePaths
B) Drill Down to Web Requests Dashlet
C) Right-Click and select "Group By" "Application, URI and Query"
D) copy/paste to excel
Andreas make a good point about sharing the Dashboard instead of copy/paste.
thanks,
Ted
Comment
0 Show 0 · Share
avatar image
Answer by Sanjay S. · Dec 02, 2013 at 09:08 PM
Thanks Andreas and Ted. I did actually mean HTTP query string and thanks for that. I am sure I will eventually need the tip you send Andreas (smile)
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
