• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Kalyan G. · Jan 24, 2014 at 10:07 PM ·
Conditionally switching on/off dynatrace
We are instrumenting our C++ code manually using ADK
We check for an environment variable to call DYNATRACE_INITIALIZE . Assumption is that if we don't initialize then subsequent dynatrace adk calls should not create purepaths. i.e; calling ADK macros should not affect the code. Is this correct?
How much performance hit it would be to just call for the ADK macros or dynatrace api methods un-conditionally?
What is the best way to turn on and off dynatrace in runtime ?
thanks,
Kalyan
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Bernhard L. · Jan 28, 2014 at 09:29 AM
Absolutely correct - if the ADK is not initialized any calls will return immediately. Overhead is just the method call and the check for the "is initialzed" condition. ADK calls, which return so-called tags will return "dummy tags", which can be safely used as input parameters as well.
Note that disabling an (ADK) Agent is fairly easy by disabling the "Capture Events" flag in the System Profile / Agent Mapping. This allows to turn off Agents being mapped to that specific Agent group even during run-time, no restart necessary.
Best regards,
Bernhard
Comment
0 Show 0 · Share
avatar image
Answer by Kalyan G. · Jan 28, 2014 at 09:32 PM
Thanks for your reply.
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
