• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Tamás V. · Jan 28, 2014 at 02:29 PM ·
dynaTrace 5.6 - weak cert question
Hi everyone,
We are planning a dynaTrace upgrade from 4.2 to 5.6.
I've read the known issues in dynaTrace 5.6, and one thing is not clear:
Java 7 does not accept weak certificates by default. This might lead to refused connections e.g. when authenticating to a secure LDAP server with a weak certificate.
Is this saying that if we're using LDAP for dyna users/groups (we do), there is a chance we'll face this refused connection problem after upgrade?
And by certificate, it mean SSL certificate, right? If yes, how can i decide if a certificate is weak, or not?
In our dynaTrace server settings under Users -> LDAP, the "Use SSL connection" checkbox is NOT checked, so we're not using secure connection to the LDAP server, and therefore we won't face this issue, am i right?
Thank you in advance!
Best regards,
Tamás Vincze
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Kurt A. · Feb 05, 2014 at 02:14 PM
Hello Tamás,
Java 7 does not accept weak certificates (i.e. certificates using weak hashing or signing algorithms, for instance MD2 or an RSA key of size < 1024) by default. This might lead to refused connections e.g. when authenticating to a secure LDAP server with a weak certificate.
Does this answer your question?
Kurt
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
